G1000 vista diesel
Terry
12-19-2002 17:34:11
Engine oil getting into radiator after water pump has been completely rebuilt by qualified dealer. The engine has been rebuilt and checked for cracks. What is wrong?
Next Question
Hydraulic releif plug blowing out of valve. The pressure regulator on pump has been rebuilt. Old plugs are aluminum new plugs are steel. Is this an update? What causes them to blow out?
Harrold Rhodes
12-20-2002 09:04:35
 Re: G1000 vista diesel in reply to Terry, 12-19-2002 17:34:11
The early Vistas used open center hydraulics, later ones closed center. If yours is closed center the most common problem is air in system. You remove air by looping a hose into one of hydraulic couplings and engaging that remote valve and operating until air is removed.
