Changing motor in r to zb motor
peter
12-21-2002 14:18:07
witch flywheel should i use ? is there anything else to consider? how will it pull? anything else i can do to make it pull better? thanks in advance
Pete Brandel
12-22-2002 09:40:57
 Re: changing motor in r to zb motor in reply to peter, 12-21-2002 14:18:07
This is a very simple swap.You just have to use the R flywheel and clutch.The clutch is adjustable and can be tightened if it would slip.I have a ZA motor in my R that has M&W aluminum .125 overbore pistons,Berry reground pulling cam,and 10A2647 LP head.It dynos at 50HP at stock RPM.The clutch has been holding up real well.I also switched it over to 12 volt system for easier starting.It has 12.4x38 tires and is competetive in the 3500 lb class.
