Belt Pulley Question
David Smith
12-30-2002 16:05:18
Hey guys i just bought a gb lp tractor and i would like to be able to put this tractor on a sawmill but it doesn't have a belt pulley (all it has is the cover on the transmission) I looked at my uts diesel today and it looks like the belt pulley and gear and the housing would fit the gb. Do you guys know if a u belt pulley gear and housing will fit a gb?? If so does anyone have one they would sell for a reasonable price? Thanks a lot guys!!!!
Roger
01-02-2003 06:51:16
 Re: Belt Pulley Question in reply to David Smith, 12-30-2002 16:05:18
David, the belt pulley from the U will fit the GB.
Drive the U up on a blocks so it will lean over to
the left. This way you don't have to drain the
oil. Remove the belt pulley and replace with the
cover from the GB. If the belt pulley has a
nuetral, this is a good time to lube it so it will
work better.
Kevin Moschenrose
12-30-2002 20:43:33
David Yes it most definitely will will work in it. I have a pulley for one but no complete assy.
