Cherry red wheels
peter
01-08-2003 14:01:12
color on mm board for red wheels can not be matched at car quest i need better or more current numbers thank you
Lester Wenzel
01-21-2003 20:00:00
 Re: cherry red wheels in reply to peter, 01-08-2003 14:01:12
Peter: Use Case-IH (early version} or New Holland red. Thanks, Les
Loren
01-16-2003 16:40:11
I dont know what all you guys think about this but i use Masey Furguson Red on all my red parts on my U's. I've did 5 molines wiht this and i belive its the reddest red you will be able to find.
G. L. Perry
01-11-2003 19:02:59
I used Case/IH red (rouge) on my 335 wheels, I liked it. Who cares if it's exact match? Looked plenty RED to me, and wasn't that expensive. The primer they have is great too, dries fast and smooth. They use Xylol for thinner. I'm now using their Industrial yellow on my later Jet Star 3 and it looks real close to orig.
John
01-08-2003 18:27:46
Ask your paint man if he can mix cherry red for a 1929 Chevrolet. Several years ago I had a gallon of MM cherry red mixed at NAPA (Martin Senour Paint) The NAPA guy was looking in his book and commented that the same formula for MM cherry red also matched 1929 Chevrolet red.
Good luck,
JM
Kevin Moschenrose
01-08-2003 21:50:24
 Re: Re: cherry red wheels in reply to John , 01-08-2003 18:27:46
Go with John's idea first I work for Sherwin Williams and they own Martin Senour Paint. If not you can use a Massey Harris red it is darn close too.
Tom-Mn
01-09-2003 06:34:11
 Re: Re: Re: cherry red wheels in reply to Kevin Moschenrose, 01-08-2003 21:50:24
The spanish guy, Senour-Martin, sold at Napa stores--
Cherry Red-53B-540
Prairie Gold-53A-3749
John
01-09-2003 12:01:45
 Re: Re: Re: Re: cherry red wheels in reply to Tom-Mn, 01-09-2003 06:34:11
One more thing. Be prepared for sticker shock when you buy red paint from an automotive supply. It is worth it for the quality though. JM
Painterman
01-09-2003 17:27:55
 Re: Re: Re: Re: Re: cherry red wheels in reply to John, 01-09-2003 12:01:45
Car Quest has problems matching most anything. Stick with NAPA paint and the rest.
Keith
01-10-2003 16:05:15
 Re: Re: Re: Re: Re: Re: cherry red wheels in reply to Painterman, 01-09-2003 17:27:55
Give the John Deere red a try. The sticker shock won't bite you either. I used it on a ZTS restoration and didn't look too different than the parts store mix I used on a UB, A LOT cheaper too.
Skip
01-11-2003 19:11:08
 Re: Re: Re: Re: Re: Re: Re: cherry red wheels in reply to Keith, 01-10-2003 16:05:15
I would be afraid the old GB would rollover and die if I used JD. paint on it!!!!
