MM602 CARB SOLVED
JEFF RZEPKA
01-29-1999 04:26:56
I SOLVED THE PROBLEM LAST NIGHT CONCERNING
THE POSTING A COUPLE BACK.
THE CARB WAS INDEED WRONG IN THE SENSE THAT THE THROTTLE SHAFT WAS TURNING CW TO INCREASE RPM.
IT SEEMS SOMEONE REBUILT THE CARB AND INSTALLED
THE THROTTLE PLATE BACKWARDS(TILTED THE WRONG WAY)
ONCE I CORRECTED THAT THE GOVERNOR STARTED WORKING
JUST FINE. NOTE: I'M SURPRISED THAT THE TRACTOR
EVEN RAN WITH THE THROTTLE BACKWARDS. JUST IDLED
A LITTLE ROUGH AND GOVERNOR DIDN'T WORK.
JEFF
