Head bolt torque values.
Mike (MI)
01-16-2003 07:01:50
The engine I'm working on is in the M5 diesel, the D336. I'm wondering why there is a difference in head bolt torque from one side of the engine to the other. I understand the 9/16" studs would be torqued less than the 5/8" studs - buy why the difference between left and right side on the 5/8"? I'm considering replacing the studs with new ARP studs, but don't want to overtorque them if there was sealing problems, or thermal expansion problems. Does anyone have any design history with this engine? Any info would be appreciated.
Thanks, Mike
Mike (MI)
01-16-2003 09:53:23
 Re: Head bolt torque values. in reply to Mike (MI), 01-16-2003 07:01:50
Thank, guys. That makes much more sense.
Mike
Captainhookerus
01-16-2003 08:53:07
Mike the last torque specs were for 170 on big bolts and 135 on small ones. If you don't tighten them equally in a circular motion you run the risk of distorting valve seats and cracking head.
Derrick Wolter
05-01-2004 11:52:54
 Re: Re: Head bolt torque values. in reply to Captainhookerus, 01-16-2003 08:53:07
Are these the torque values for all the bolts if not do you know them?
I am restoring a ZA moline and im not quite sure one what to torque the bolts too?
Kevin Moschenrose
01-16-2003 08:28:58
I have a 57' 5-star with the D336 engine in it. I was told the there had been a update on the head bolts from the factory to torque them all to the 125 to 130 ft. pound range on the 5/8" studs. I was told this by a MM dealer and I done it five years ago and no problems.
