1932 KT twin city around 2077 produced
Scooter
01-16-2003 17:53:33
Any TC collectors around that might have a model KT? What would the survival rate be and an approx value? The tractor is in real good shape and running great but needs paint
M Hornick
01-16-2003 19:14:51
 Re: 1932 KT twin city around 2077 produced in reply to Scooter, 01-16-2003 17:53:33
There are several KT's around, we have a couple, and a couple KTA's also. One thing to check before painting is if or more likely how bad the water pump leaks @ the front packing nut. You can put more grease and packing in there, but some times the shaft is really worn. I've got mine tore apart right now and the shaft is about half dia. @ the front packing nut. (Note, if you put more packing in, the large brass nut is LEFT hand thread)
Price will depend on Steel, cut-offs, or factory cast centers. Condition of rubber, and you. If your after completely original you will want to spend some time with a parts book. They made alot of changes and upgrades on these. For ex. they used 3 different Carbs, and one of them in two different times.
Mike
