Getting max. horsepower out of a gas UB
sam
01-16-2003 19:15:15
I am interested in rebuilding this tractor and would like to find out what is the most horsepower that I can achieve. I basically would like a total overhaul to be the most that it could be,,..i pulled this tractor in the stock class and would like to move up to the next level..If anyone has any specs or experience on this gas motor I would enjoy hearing from you...thanks
u puller
01-18-2003 15:50:58
 Re: getting max. horsepower out of a gas UB in reply to sam, 01-16-2003 19:15:15
try a set of heads off a G 1000 LP
SS
01-16-2003 21:16:47
Sleeve it to 5.5" or 5.75" stroke to 7.5" around 160-200hp depending on the heads and rpm and dollars .
in reply to SS
01-17-2003 09:25:02
 Re: Re: getting max. horsepower out of a gas UB in reply to SS, 01-16-2003 21:16:47
could you also tell me what would be the specs on rebuilding this same engine with orginal parts for maximum horsespower so that we can get a perspective going from orginal to what you specs you have given,,thanks for your time...sam
Andy
01-17-2003 19:20:10
 Re: Re: Re: getting max. horsepower out of a gas UB in reply to in reply to SS, 01-17-2003 09:25:02
If you want to keep it closer to stock you can put LP heads, (4206 or 4213) and an LP manifold set on it. M&W pistons in stock blocks and a good cam grind helps too. I have a 65 hp U with this combination,(it's for sale!).
SS
01-18-2003 10:56:42
 Re: Re: Re: Re: getting max. horsepower out of a gas UB in reply to Andy, 01-17-2003 19:20:10
The trick to the whole thing is getting the air in it. Like Andy said the LP manifold 4206 heads then open up the ports smooth everything out and what seems to really help is opening the chamber around the valves because they are so close to the edge and are shrouded by the chamber wall. Maybe have the heads shaved and 5020 ex valves will work for intakes they are 1/8 bigger but are no help if you don't open up the chambers and under the valve itself. Good Luck
Les Wenzel
01-21-2003 19:04:18
 Re: Re: Re: Re: Re: getting max. horsepower out of a gas UB in reply to SS, 01-18-2003 10:56:42
SS: Install M5 blocks and 4-5/8" pistons, can supply, you can call me at 507-465-3334 or 507-465-8238. Thanks, Les
