Manifold brackets
Rocky
01-20-2003 09:11:03
Wanted: 4 castiron brackets that hold the manifold on a late model U. The number 10A0472 is molded in to the castiron. I believe they have a 5/8 hole in them that is offset. Thank You!
Les Wenzel
01-21-2003 18:45:06
 Re: manifold brackets in reply to Rocky, 01-20-2003 09:11:03
Rocky: I have these clamps on hand,orginal. You can call me at 507-465-3334 or 507-465-8238, Thanks-Les
Andy
01-21-2003 17:10:21
You can make them. I used colded rolled flat bar,.75" thick, 1.625" wide 4" long and drill a .5" hole centered 1.75" from one end. You may have to bevel the corners a bit so they lay on the flat spots of the maifold.
