MM info?
Joe Todd
01-22-2003 14:25:17
My father-in-law has a MM with the model listed on the metal s/n tag as 283B-4 and serial # 06104399. He purchased the tractor many years ago from an old farmer that said it was a 1950 or 51, but could not remember. It is now propane powered. The propane tank is dated as 1965. I am trying to find out anything that I possibly can about it and am wondering if it is worth restoring. It is in desperate need of all rubber and a paint job. The tractor does run and was being used last year until the rear tire went flat. I appreciate any information on this. Thanks, J. Todd
BMG
01-22-2003 14:34:21
 Re: MM info? in reply to Joe Todd, 01-22-2003 14:25:17
Joe,
You've listed the engine serial number. The tractor serial # is located on the right side of the trans housing above the belt pulley. From the engine serial # you've listed I can tell you the engine originally was installed in a 1953 UB tractor. If its the original engine your tractor should have a foot clutch and a high operators platform with a centered steering wheel. UB serial #'s were specific to what type of front end they had but they didn't differentiate between gasoline or LP. Diesels had their own serial #s. Post the tractor serial # and we can tell you more about it.
Brian
