MM UB IGNITIONMORE POWER
DARRYL KRAUSE
02-02-2003 20:06:35
I HAVE A 54 UBE THAT IM BUILDING FOR TRACTOR PULLING IN THE 6000 LB. CLASS. AS FAR AS MOTOR WISE,THE ONLY THING I HAVE DONE TO IT IS GOT IT UNSTUCK PUT NEW PLUGS WIRES AND CAP AND ROTOR. IT HAS THE 10A4213 HEADS WHICH I READ SOMEWHERE ARE LP. IM GETTING ALMOST 58 HP. OUT OF IT WHICH IS NOT BAD.IM HOPEING TO GETA LITTLE OVER 70 HP WHEN DONE WITH IT. I CANT SEAM TO FIND THE PENTRONIX IGNITION FOR IT AND WOULD LIKE TO KNOW A PART # OR WHO HAS A NEW ONE.ALSO I HEARD THAT A M5 MANIFOLD WOULD WORK ON IT? I AM GOING TO SHAVE THE HEADS ABOUT .025 TO .030 FOR MORE POWER WHAT CAN I DO TO GET MORE POWER FOR UNDER $500.00 IM GOING TO TURN 18.4X38 TIRES ON THIS. ANY INFO AND HELP WOULD BE GREAT. THANKS FOR YOUR TIME,DARRYL.
Tom in Mo.
02-03-2003 15:29:33
 Re: MM UB IGNITIONMORE POWER in reply to DARRYL KRAUSE, 02-02-2003 20:06:35
Genessee Products 918.274.8000 between 8 and 5 central time. I would recommend the high output coil they offer with their electronic ignition.
DARRYL KRAUSE
02-03-2003 20:52:41
 Re: Re: MM UB IGNITIONMORE POWER in reply to Tom in Mo. , 02-03-2003 15:29:33
thanks for the info tom, i wiil give a call tommorow!
