Looking to buy an MM
M.Smith
02-07-2003 14:04:26
I am interested in finding a good MM project tractor. I don't know any thing about the MM's, all I have is JD's. I like the looks and size of the R and RT. Is this a good model to start with? How easy is it to find one? I don't want to start looking for a rare and pricey MM. Are there any problems I should look out for on these models?
Thanks,
Mike
Jethro
02-09-2003 05:45:42
 Re: Looking to buy an MM in reply to M.Smith, 02-07-2003 14:04:26
Mike where are you located? I know of an RTU in Central Ohio that may be available.
M.Smith
02-10-2003 13:36:11
 Re: Re: Looking to buy an MM in reply to Jethro, 02-09-2003 05:45:42
I'm in NC near Charlotte, I really need to find one close to home.
Rick
02-08-2003 05:49:06
I have a MM m670 lp tractor want sell,runs not bent up$2300.00 obo
Wendel
02-07-2003 18:11:14
I have a 1950 RTU Moline that I would sale. It runs but not strong. Does not have good tires. Are you interested in something like that? I'm in southwest Missouri.
BMG
02-07-2003 14:33:01
Mike,
Moline made over 20,000 R models in various configurations from 1939 to 1954. The RTU with the narrow front is the most common by a long shot. I would suggest looking for one that the motor is not stuck as you can spend a few dollars on an R engine if its in rough shape. Parts are harder to come by compared to JD. Look for one with good rear rims. 34 & 36" R rims can be difficult to find but not impossible. There were 2 different rear rim center hole openings depending on year. A good radiator shroud/grille that's not rusted out at the bottom is a plus also along with a good useable hood. Early models had the hinged/louvered hood sides and later models had a one piece non-louvered hood. You may consider a ZT too which was similar in styling but weighed a little more. I've got 9 MM Rs in my collection so if you've got any specific questions just ask. I'm sure I or someone else on this board can answer them for you.
Price range in the midwest seems to be a couple hundred for a parts tractor to a couple thousand for a very nice original or restored example. You should be able to find a good R in your price range.
Brian
farmerjosh
02-07-2003 14:21:35
Mike,....I have a pair of ZTU's I would sell...both narrow front..engines are stuck...I'm located in northeast missouri id you are interested....Josh
