MM G intake manifold
Jack
02-08-2003 15:18:53
Can someone help with this number.It's F5 338.I'm hoping it will go on my 1950 G.Thanks for your help
deadeye
02-08-2003 15:54:57
 Re: MM G intake manifold in reply to Jack, 02-08-2003 15:18:53
Jack:
Here is what I have for a GTB numbers. FE338C intake, FE5339C or FE339C with studs. This is on the 403-4 engine. On the 340-4 engine, it is GE62B intake and KE821F exhaust. On the 283-4 gas "U" the numbers are KE822A or KE5822E intake and KE821G exhaust. LP's are KE822D intake and KE821F exhaust. Hope this helps---deadeye
Jack
02-08-2003 16:55:43
 Re: Re: MM G intake manifold in reply to deadeye, 02-08-2003 15:54:57
DEADEYE I THINK I GOT A GTB INTAKE.MUST BE FE BESIDES F5.WILL IT FIT MY G...THANKS FOR THE HELP..... ...JACK
deadeye
02-09-2003 08:49:56
 Re: Re: Re: MM G intake manifold in reply to Jack, 02-08-2003 16:55:43
Yes,I think it will work. If you look real close at the casting number again, it will probably turn out to be an FE instead of an F5. They are definetly close enough numbers that interchange just going by the ending numbers.
