MM Tractor ID
Bill Cebula
02-13-2003 05:20:02
I am looking at 2 MM tractors. One is said to be a "Small G" and the other a "U". Both are propane. The rivited ID plates are missing from both tractors. How can I determine the model of the tractors? Are SN's stamped at some other location?
Thanks, Bill
Bill Becker
02-13-2003 06:50:21
 Re: MM Tractor ID in reply to Bill Cebula, 02-13-2003 05:20:02
There are ID tags for both the engine and the tractor. If they are both missing, you might be able to identify the tractor with casting numbers from the heads and blocks.
Bill Cebula
03-04-2003 19:15:11
 Re: Re: MM Tractor ID in reply to Bill Becker, 02-13-2003 06:50:21
I looked at the ID plates on the engines.
One is marked 340 A SN 04000221
The other 41/4 x 5 283A 4 SN 01906095
I went through the table of SN's but didn't find any matches. Any other palces to look?
