BF motor?
Jim
02-14-2003 15:03:50
What motor is in a 1951 MM-Avery BF? Some have said some Oliver motors are the same. It would make looking for parts easier. Thanks for your time.
Kelvin
02-14-2003 17:38:00
 Re: BF motor? in reply to Jim, 02-14-2003 15:03:50
Like Dick said, The BF has a Hercules engine. It is either a model IXB-3 or an IXB-3SL. I understand that the SL stands for sleeves. Oliver used about the same engine in their OC-3 crawler.
If you look at an OC-3 close you will see a lot of other similarities to the BF as well, because the basic design of both goes back to Cletrac. B.F. Avery bought their wheel tractor line and Oliver ended up with the crawler. In about 1951 MM acquired BF Avery.
Other equipment used the Hercules IX series of engines as well. I've seen one on a welder, and I was told that Baker forklifts used IX engines as well.
It would definately be worth a shot checking with Oliver parts suppliers for engine parts.
Dick
02-14-2003 15:32:27
I have a 1952 Bf and it has a Hercules engine in it.
