Carb on ZTU
Jason
02-14-2003 17:32:18
I have a MM ZTU with a model TB carburator on it, and I would like to know where I can have it rebuilt or find one that is already rebulit.
Jim Parisot
02-15-2003 10:07:37
 Re: carb on ZTU in reply to Jason, 02-14-2003 17:32:18
Jason, my question is what is a model TB carburetor? Early ZT's used a Schebler Model TRX-12 carb and later ones use a Marvel Schebler Model TSX-97.
Jim
Jason
02-16-2003 05:48:02
 Re: Re: carb on ZTU in reply to Jim Parisot, 02-15-2003 10:07:37
Correction, The carburator on my tractor is a model TR. there are no other letters or numbers, but it is made to bolt on to the air intake and to the intake manifold. Is this a TRX-12 or has someone put a different carb on it?
Jim Parisot
02-16-2003 14:14:07
 Re: Re: Re: carb on ZTU in reply to Jason, 02-16-2003 05:48:02
Jason,
Are you reading on the side of the carb where Schebler Model TR is CAST in? If so, look on the other side and see if you find a small brass tag. It should have TRX - 12 stamped in. Hope this helps.
Jim
deadeye
02-15-2003 04:15:02
Get a hold of Matt @ Motec Eng. Here is his e-mail. MotecEngr@aol.com He does good work and is very reasonable on price. If I was rating Denny's and Motec on a 1 to 10 basis, it would be like this.
Denny's - 3
Motec + 9
Nuff said.----deadeye
Moline
02-14-2003 18:17:26
I had mine done at Dennys Carb Shop.He did a good job and I am very happy with it.You can find him on the internet,just search Dennys carb shop.Good Luck
Denny,s is a joke
03-05-2003 13:42:47
 Re: Re: carb on ZTU in reply to Moline, 02-14-2003 18:17:26
If you want someone to paint a junk carb and charge you $200 call Dennys
WHAT???
02-26-2003 13:03:38
Denny's is the biggest rip-off out there. It will cost you over $175 get get your old carb painted. Then he will cuss at you when you call and complain. DO NOT GO TO DENNY'S!!!!! !!!
John G
02-14-2003 18:33:58
Go to the MM site & look for Motec Eng. they rebuild carbs and dist for MM cheap!!
