MM ZTU Carb icing up
Chris
02-15-2003 16:21:23
My carb on my 1950 ZTU forms ice on the tube between the carb and intake manifold. Does this shortly after start up. Any info?
havvey
02-16-2003 13:03:45
 Re: MM ZTU Carb icing up in reply to Chris, 02-15-2003 16:21:23
certain weather atmosferic conditions do this its common in my area and will shut an engine down check this on you skipping engine it is caused buy the airbeing drawn in the only cure is to let it set or put a heat tape on it
