Disk brake conversion
cs
02-16-2003 07:22:04
Can the disk brakes off a GB be installed on a late model UTU? Thanks Chris
LW
02-17-2003 16:09:19
 Re: disk brake conversion in reply to cs, 02-16-2003 07:22:04
It would be alot easier to use the brakes off of a UB they are disc too, if you must use the G style disc you will have to mill down a 1/2" flat(in the flange of the axle housing) across and pass the 2 holes that are closest to the brake the housing on the UTU is almost a 1" thick and the G is only 1/2 were the bolts are recessed to clear the backing plate. LW in N.C.
