MM Diesel heads
Case
KFB
02-20-2003 19:20:38
Anyone used CASE heads on a MM diesel? Case head that has direct injection that is. Wanting to know more information.
Terry
02-22-2003 16:17:58
 Re: MM Diesel heads - Case in reply to KFB, 02-20-2003 19:20:38
No it will not work ports and head bolts are different. tried to do it on a vista diesel . even though they had same cubes no exchange heads or gaskets. worked for case many years owned minnie's several years. Ithink they exchanged ideas sometime would really be neat to know
Kevin Bauza
02-28-2003 19:18:28
 Re: Re: MM Diesel heads - Case in reply to Terry, 02-22-2003 16:17:58
I think Case, Moline, AND CUMMINS were all in bed together thru the years. There are a lot of similarities. I seen a prototype Case LA diesel powered by a CUMMINS diesel. The story goes that the diesel option cost as much as the entire gasoline LA tractor, so it never was launched on a commercial scale.
