U waterpump pin
Andy
02-21-2003 09:55:17
I put together a U waterpump and the drove the roll pin throuth the impellar and shaft. It is not as tight as I'd like it to be. I'm concerned that it will work it's way out. Has this happened to anyone? I was thinking of using a large cotter pin instead,(anyone done this?) thanks.
E J
02-22-2003 11:24:37
 Re: U waterpump pin in reply to Andy, 02-21-2003 09:55:17
Bore the hole out bigger and put a new role pin in it .Impeller is left hand threads would not work loose any way.
Kelvin
02-21-2003 16:53:56
If its the kind of pin with a hole in it, why not just safety wire it? You should be able to come up with some stainless wire somehow.
