335 serial number questions. What is IT???
larry
02-21-2003 17:15:38
This is the tractor in the post below. Now I have a real question. This tractor's serial number is 11300300 which makes it a Universal. However is tractor looks JUST like a Utility. What is the difference if any?? Does this make it any more rarer?? Thanks Larry
JK
02-22-2003 05:53:21
 Re: 335 serial number questions. What is IT??? in reply to larry, 02-21-2003 17:15:38
Larry,
The serial number you gave is for a 1957 335 industrial. A Utility would start weith 104 & a Universal with a 116 instead of 113.
The Industrial may have any or all of the following not normally found on a utility: 12 bolt rear wheels & axles instead of 6 Fixed width wide I beam type front axle Reverse Shuttle instead of Ampli-Torque
Some distinguishing items on a Universal: Bolt on 9 bolt axle hubs instead of forged 36 inch rear wheels instead of 24-28 3 point lower links are 2 inches longer Steering housing has a top tapered roller bearing to support the changable front end types (wedge) where the utility & ind have a shaft with bushings only
Hope this helps
John
