G1350
RickB.
02-22-2003 09:25:01
Found out Friday I will be working on a MM G1350 soon. Searched through the I&T manuals at the dealership looking for one covering this model. Didn't find one, but did locate one for White 2-150 among others. Will this provide sufficient info to guide me through a slipping PTO clutch, brake overhaul, and a leaking rear axle (planetary?)seal? Thanks in advance, RickB.
Bill
02-24-2003 16:31:04
 Re: G1350 in reply to RickB., 02-22-2003 09:25:01
Rick, I own an Oliver 2155. A G1350 painted
green. IT does make a shop manual, I have one.
You can buy an operators manual, a shop and a
parts manual as well. What year G1350, will you
be working on ? any pictures?
DAN
02-23-2003 08:03:45
I am working on a G1355 Moline. I am using an o-202 I&T manual. It will answer all your ?s for your G1350. If you have trouble finding one, e-mail me and I can get you one. I can also get parts - I'm an Agco dealer. Dan
Phil Munson
02-22-2003 14:29:59
I think that the 1350 was very similar to the 1050, excepting the engine and the outboard planetary finals.
M. Tessman
02-22-2003 10:49:19
Rick: The 1350 has all Moline components from the flywheel back. The White 2-150 has the Oliver rear end. They are totally different. The only things that they have in common are the engine, front end and the planetary set-up in the wheels. MIKE
RickB with another question.
02-22-2003 11:13:44
 Re: Re: G1350 in reply to M. Tessman, 02-22-2003 10:49:19
Thanks. My understanding is the MM1355 is also an MM powered Oliver chassis. Is that correct?
steve
02-22-2003 12:39:18
 Re: Re: Re: G1350 in reply to RickB with another question., 02-22-2003 11:13:44
yes Rick you are correct the MM 1355 came in MM yellow Oly green & also as a White 2270 all that realy differed in these three models was the tin.That info comes from first hand knowlage it can also be found in CH. Wendels Encyclopedia Of American Farm Tractors. Steve
