MM335
ROSCOE RICHARDS
02-23-2003 09:02:54
I JUST PURCHASED A MOLINE AT AN AUCTION.
THE TAG ON THE SIDE OF THE TRANSMISSION SAYS
MODEL A1P SERIAL 10401708
ENGINE MODEL 1054- SERIAL 10302236
WHAT YEAR IS THIS? I THINK IT IS A UTILITY,
BUT WHAT IS THE DIFFERENCE FROM A UTILITY AND A UNIVERSAL?
THIS IS A 335 ISN'T IT?
Haas
02-24-2003 08:32:46
 Re: MM335 in reply to ROSCOE RICHARDSON, 02-23-2003 09:02:54
A Universal is a row crop tractor with tall rear wheels. Both front and rear wheel are adjustable, so you can adjust them to the width of your rows.(often tricycle front end)
A utility has the shorter rear wheels and always a wide front end.
Allan
02-23-2003 10:29:04
It is a 1957 Utility. Information found on this web site under Research&Info,Serial Numbers. As far as the differences, someone with more knowledge will have to answer that.
Herschell Black
08-21-2004 17:19:29
 Re: Re: MM335 in reply to Allan, 02-23-2003 10:29:04
Sirs,
I would like to find out about what one in good condition would be worth,and if someone could put a power takeoff on it. The model # on the transmition is A1P and the serial# is 10400395.
The model# on the engine is165A 4 and the serial # is 10300727
