MM UB weight
Dodge
02-23-2003 21:13:02
Could someone tell me what a MM UB gas, tractor might weigh without any wheel weights or fluid in the tires. Thanks in advance for the info!
E J
02-24-2003 11:39:25
 Re: MM UB weight in reply to Dodge, 02-23-2003 21:13:02
I have a ub also nf. fenders no belt pulley stock cast wheels 13.5x38 no hydralics and lift arms wt. 5500lb.
BRAIN
02-24-2003 09:03:53
I have a 53 UBE with no wheel weights and no fluid in the tires. The weight is 5,920 pounds. You can figure more weight with a wide front end. Not sure what the add weight for the wide front is.
