MM GBD injector pump
Joe
02-24-2003 15:43:25
1954 MM GBD injector pump does not start well,tranfer pump seems to be working, could it be the camshaft in the injector pump worn out. It also pops alot when warming up.
George
03-02-2003 17:47:26
 Re: MM GBD injector pump in reply to Joe, 02-24-2003 15:43:25
Check half moon key on injection pump.As far as the popping get use to it. good luck.George
Captainhookerus
02-24-2003 16:09:08
Joe the first thing to do and this is simple. Remove the self locking nuts or lock washers holding the nozzle holders in the heads and retorque plain nuts to 15 to 20 ft lbs. Make sure fuel filters and fuel flow to pump is good with new fuel. Give this a try before fixing injection pump.
