38 inch 'U' rear rims
Dave
02-24-2003 21:15:27
Is there a way I can put a 15.5 or 18.5 X 38 outer rim on my original U cast iron rear wheels?
Thanks
L.P.
03-03-2003 11:45:00
 Re: 38 inch 'U' rear rims in reply to Dave, 02-24-2003 21:15:27
Farmall H,M,Super H,M IH early 300,400 will also fit.
galen
02-25-2003 17:16:36
M5 with cast centers should intercxhange
John G
02-25-2003 05:50:54
All you have to do is find the width rim in 38" and put it on, industry standard wheels. I have a pair off a JD on my UTU.
DAVE
02-25-2003 21:26:51
 Re: Re: 38 inch 'U' rear rims in reply to John G, 02-25-2003 05:50:54
John G., did you use the JD taper lock blocks which press OUTWARD from a JD cast wheel. I thought about that but didn't see how I would be able to apply that to the MM cast wheel, because the MM cast wheel blocks virtually tug the MM inter ring right up to the cast MM most outer edge. Are JD 38" different on the old two cylinders vs 3010-3020 series. Thanks, Dave
John G
02-26-2003 03:21:08
 Re: Re: Re: 38 inch 'U' rear rims in reply to DAVE, 02-25-2003 21:26:51
Mine are off the A-B-G vintage stuff.
