G-1000 Vista Closed Center Pump
Fran
02-26-2003 10:57:59
One of our three Vista's has the closed center hydraulics. The pump was weak and now does nothing at all. How do we rebuild it or who does this, or where can we find one that works properly. I beleive it is similar to the ones used on later White models but the vista's drives off the timing gears so I'm sure they must use a different adaptor or drive.
Anyone have one that will work or any info would be greatly appreciated.
Kevin Bauza
02-28-2003 18:45:45
 Re: G-1000 Vista Closed Center Pump in reply to Fran, 02-26-2003 10:57:59
Are you absolutely sure the pump is weak, or has the compensator adjustment backed itself out? I bought a G-900 once which this happened to. Some folks turn the adjustment to lower pressure to conserve the lifespan of the system; when they are just pulling wagons etc, and don't really need hydraulics. CAUTION: DON'T SET THE PRESSURE TOO HIGH OR YOU WILL OVER RIDE THE SAFETY BYPASS. This will cause the pump to supply oil non stop and cook your system
Fran
02-28-2003 20:02:23
 Re: Re: G-1000 Vista Closed Center Pump in reply to Kevin Bauza, 02-28-2003 18:45:45
Thanks Kevin for the comment. I am not sure but it seems to me that we tried adjusting that compensator once ourselves trying to get it to work better. We haven't used it for a while. That was a couple years ago and you know the memory is the first thing to go. I'll check into it though.
David
02-28-2003 09:11:04
I have a pump for your tractor that has not been used since it was professionally rebuilt and checked. Email for details.
Dale
02-26-2003 13:41:23
We have used pump that will fit your needs. 920 295 3278, or riverdalefarmshop@yahoo.com. Dale
