Hi speed uts
fran dakota
02-27-2003 15:15:47
In the early 40's the mm uts had a high geared rear end would go close to 30 mph. any body know what serial numbers these were. My dad spoke of one the neighbor had and would go to townwith in winter 1948 1949 get gocerys and mail for the neighbors.
freddy
03-03-2003 12:23:06
 Re: hi speed uts in reply to fran dakota, 02-27-2003 15:15:47
I was talking with Clint Stamm a while back and he was doing a restoration on a udlx. his words on this is that they have and what I seen is that they have two shifters and a governor override that made them so fast.He said the secound shifter can't be shifted in to until the first shifter is put in neutral. this allows the complete bypass of the transmission with a mechanism to direct drive the engine to the ring gear and pinion. He also said besides that, they were pretty normal industrial u parts, brakes on the axles. not on the bull pinions. like big truck brakes.
dean
03-02-2003 17:21:22
not to start anything but was at roger mohr's place some time ago in vail and looked at his udlx..he said the udlx's had 2 transmissions to enable them to reach the speeds they did..not just a ring and pinion..i looked and it had one in front of the other..dont know how this was accomplished but thats what he said and i think he is pretty much an authority on these things..certainly has an impressive collection
Jeremy
02-28-2003 19:55:41
The serial number for the last transmission like the UDLX and early U's was 327400. That rearend was used last in 1946. The rearend castings are also differen't between the 327400 and prior transmission verses the transmissions after 327400. The ring gear and pinion is what makes 5th faster.
for some reasion this wont leave the table up here so you have to go to the bottom to see it. nebraska tractor test results
  uts utu udlx U
test date Oct 24 to Nov 16 1938 June 13 to 17 1938   May 27 to June 7 1954
tire size rear 12.75 X 32 11 X 36 12.75X32 12 X 38
1 2.7 2.5 2.7 2.5
2 3.5 3.2 3.4 3.6
3 4.7 4.3 4.7 4.2
4 6.2 5.7 10.1 6.0
5 20.2 18.5 20.1 14.0
no gov???     28.1
Rev 1.3 1.2 1.3 2.0
Jeremy
Keith
03-02-2003 15:58:39
 Re: Re: hi speed uts in reply to Jeremy, 02-28-2003 19:55:41
Just a thought, if it is the ring gear and pinion ratio that makes 5th gear faster, would not all of the gears be faster. All output to the rear axles goes through these gears.
Jeremy
03-05-2003 18:55:40
 Re: Re: Re: hi speed uts in reply to Keith, 03-02-2003 15:58:39
The speed for all the gears are differen't. The gears in the transmission are differen't giving them differen't ratios.
Jeremy
Dave
02-27-2003 19:50:18
Get in touch with the fella (name?) in homestead Iowa who makes the stainless steel MM mufflers. I beleive years ago he worked for an MM dealer, and has experience and facts about your conern.
Good Luck !
SWMolines
02-27-2003 19:10:13
I do not know the serial number range but you can tell them by the shifter pattern. On a regular MM U the top row of the shift pattern is 2-1-5. On the high speed units it is 2-3-5. I believe the high speeders were only made in the one piece block/head era. That is the sum of the little I know.
Andy
02-27-2003 19:28:32
 Re: Re: hi speed uts in reply to SWMolines, 02-27-2003 19:10:13
I've heard stories,(but nothing confirmed) that the High speed UTS' were UDLX rearends that were assembled in anticipation for huge sales. When the UDLX flopped, MM used them up in UTS' UDLX had a governer override to hit 40MPH. I would guess that's why the high speed UTS won't go quite that fast.
fran dakota
02-27-2003 20:29:16
 Re: Re: Re: hi speed uts in reply to Andy, 02-27-2003 19:28:32
Thanks fellas I'll check the shift pattern of the one I have in the bone pile I believe it has a one piece block
