Front Rims
Mark
03-10-2003 16:13:44
Are the front rims the same dish on a late ZA as on a M5? Will they interchange from a narrow front to a wide front? Thanks, Mark
Kelvin
03-10-2003 18:42:33
 Re: Front Rims in reply to Mark, 03-10-2003 16:13:44
I'm thinking that the ZA rims will be narrower than the front rims on the M5. The ZA probably came new with 5.50-16 tires and the M5 probably had at least a 6.00-16, maybe wider.
They should both use the same 4-5/8" center hole, so should bolt up.
You can probably use the narrow front rims on the wide front,if the tire doesn't rub the steering arm, but you really have to check rim and tire clearances if you are changing from a wide front to a narrow.
