CLUTCH ON GVI
PISTON
03-15-2003 17:13:16
NEED TO KNOW WHEN YOU CHANGE MOTOR AN USE DESIEL FLYWHEEL DO YOU HAFT TO CHANGE CLUCTH PLATES TO M,ATCH. CANT SEEM TO GET CLT. RIGHT STILL GRINING GEARS.
SWMolines
03-16-2003 14:04:48
 Re: CLUTCH ON GVI in reply to PISTON, 03-15-2003 17:13:16
Sounds like your clutch brake might be worn. This is a common problem with that series of MMs. By design, there was a brake that engaged when you pulled all the way back on the clutch handle. If the brake pad is worn, it will not be able to over come the drag in the double disc clutch. The clutch brake is installed behind the main clutch assembly.
piston
03-17-2003 17:58:34
 Re: Re: CLUTCH ON GVI in reply to SWMolines, 03-16-2003 14:04:48
thank you very much for reply .sounds like my problem. guess well haft break into again. thanks piston.
