Yes to all. It was was pretty smooth sailing up to the point you need to drive the shaft rearward. The tractor is not split and I do not have a "suitable puller", so I tried driving it rearward with a hammer and punch, seating on the detent for the allen head set screw located 180 degrees from the keyway where the key was. You can see the shaft move about 1/4" back and you can move it by hand, but it hits against the rear bearing and from what I can see (as I cannot measure - too tight) it appears the bushing travels with the shaft and is butting up against the rear bearing. It also looks like someone brazed in the rear bearing, there are burn marks on the casting and brazing around the bearing case. Te bearing case does slide out of the casting, 1/16" or better. The rear gear assembly is loose on the shaft too. The darn shaft should just glide right out the rear, but it doesn't. This is why I am at witts end with this thing.
