MM G1350 parts
RickB.
03-19-2003 04:04:45
We are looking for a competent Agco parts department with access to MM G1350 parts. Northeast US helpful, not critical. Major repairs to PTO, including input shaft and hub @ flywheel/crankshaft. Brakes and other stuff. Any input welcomed. Thanks, RickB.
freddy
03-19-2003 10:48:18
 Re: MM G1350 parts in reply to RickB., 03-19-2003 04:04:45
One word of advise, purchase a good parts manual. A lot of dealers don't have the expertise that they once had. It will make thing really fly If you just tell them the part number you need. That's how we do it. Cuts down time on the phone greatly. I know this might be a little expensive to buy 4 or 5 parts manuals, but familarize your self with all the last models of MM's. They used a lot of common parts. Good to see another MM being rescued.
freddy
03-19-2003 10:34:59
We have a G1350 and G950, nice tractors. 50 series common parts are the ring gear and pinion and the torque units with top trans shafts. 1350 and 1050 use a common transmission while the 950 and the 670 shared some parts. Bull gears and bull pinions are all different. but the fwd and rear cases are all the same. axle housing are different for the 1350 and the same for 950 and 1050 but have different outer bearing caps. all axles are different unless you got the extra long axles, then the 950 and the 1050 would be the same. no differences that I know in the pto department. Hydraulics are identical if the same features. Rims can be the same but not the hubs. As for the 900 and 1000's they have different ring gear and pinion ratio's, not the 9-49 ratio of the 50 series. bull pinions are different. Rear cases are different. brakes disks are the same. Late model vista's also have the same torque. 2 speed or 3 speed with some commonality to the 3 speed M670's.
Phil Munson
03-19-2003 09:57:28
I do not know exactly where the NE USA is for you. In upsate NY Coryn's in Canandaigua NY are pretty nice folks with whom to deal. They are long time MM folks.
RickB.
03-19-2003 15:21:46
 Re: Re: MM G1350 parts in reply to Phil Munson, 03-19-2003 09:57:28
I am in eastern NY. Will contact Coryn tomorrow. Thanks.
JK
03-19-2003 06:06:52
Rick,
If I'm not mistaken, the PTO and brakes are the same as those on the G900, G1000, G950 & G1050. Would have to check part numbers to be sure but I think they are the same. Used parts from those tractors should be a bit easier to find.
Call Wendell @ 740-922-3335. He should have what you need if you can't find it locally.
John
RIck B.
03-19-2003 15:23:38
 Re: Re: MM G1350 parts in reply to JK, 03-19-2003 06:06:52
Used parts will be considered only where new are unavailable. Thanks
freddy
03-19-2003 07:24:02
brakes on the G900 and G950 were smaller. but the rest is about the same.
Mechoman
03-19-2003 05:25:54
there is a fellow in Texas on other MM board listing 2 1350's for sale both with engine problems and a boat load of spare parts. Try www.minneapolis-moline.com Good luck ,Shawn
freddy
03-19-2003 07:25:47
 Re: Re: MM G1350 parts in reply to Mechoman , 03-19-2003 05:25:54
Where are these tractors?
freddy
03-19-2003 09:49:49
 Re: Re: Re: MM G1350 parts in reply to freddy, 03-19-2003 07:25:47
Yes I've seen them, but there G1355's. No help in the rear end department, there all oliver back there.
Mechoman
03-19-2003 08:42:30
Monahan Tx. his email is clinton_stephan@oxy.com
