G 1000 Vista Transmission Lube pump
Mechoman
03-19-2003 05:21:22
Anyone know how the lube pump is plumbed through the pto/transmission?. Prints show the pto drive shaft from the clutch is rifle drilled with perpindicular oil holes at critical locations. Also the tractor has optional transmission oil cooler plumbed to front of radiator with external lines. The cooled oil line slpits at a tee in the side of the transmission. I am wondering if this is plumbed to critical internal locations or just a way of cooling and moving the oil around as it seems some G 1000 came without lube pumps at all. Thks for advice, Shawn
