Frist gear
Don Adkins
03-22-2003 17:33:23
should my u power out in frist gear.With stock motor.so guys tell me to find m5 blocks and 6" crank. but that alot of $.I just think a stock 283 should not power out in frist gear.Im running 13'6x38.is that to big.please help!!!!! !
dlp
03-25-2003 18:12:57
 Re: frist gear in reply to Don Adkins, 03-22-2003 17:33:23
Is your governor working properly?
DON ADKINS
03-26-2003 06:49:01
 Re: Re: frist gear in reply to dlp, 03-25-2003 18:12:57
dlp my governor is not hocked up i run wide open.(5000rpm)
E J
03-22-2003 20:01:28
I pull M&M u&ub .My ub will power out in low gear in 7500# class on a power track with 282 &13.6x38 tires,4206 heads.My u has m5 blocks & 4210 heads with pop up pistons 15.5x38 tires you can't kill it in 1st.It will handle 2nd in the lighter class 5500&6000lb.but not above that.Pull div 1 with ub and div 2 with u.Working on a 403 crank in 282 crank case with m5 blocks not that expensive less than most.
DON ADKINS
03-25-2003 17:58:37
 Re: Re: frist gear in reply to E J, 03-22-2003 20:01:28
EJ dose your u have a 403 crank in it now.
Jerry
03-25-2003 04:38:44
Run a compression check. You might be low on compression. With a good engine it shouldn't run out of power in loose soil and good tires.
