Mineapolis-Moline model BF
Parts
Jerry
03-25-2003 18:38:02
I need to know where I can purchase engine sleeves and gasket set to overhaul a Hercules
engine for my BF model.
Brenda
04-08-2003 18:02:41
 Re: Mineapolis-Moline model BF - Parts in reply to Jerry, 03-25-2003 18:38:02
We got the sleeve from NAPA. It is a universal sleeve. It is too long and the piston won't go in it. It has to be pressed in and then bored to the correct size and cut off.
Brenda
03-26-2003 15:27:43
Check with your local NAPA store. Tell them to look in the "Industrial Motor" book for Hercules. They have sleeves, pistons, valves, guides, rings, etc. We have one sleeve on order right now, it is supposed to take a few days. Zimmerman has most everything but sleeves. The Oliver motor was not a sleeved engine. NAPA will want to know the sleeve thickness as there are two sleeves for the IXB3SL.
Dean
03-25-2003 18:50:11
Hi Jerry, Zimmerman Oliver-Cletrac is a very good source for hercules parts. They have all of the engine parts available. I don't think they have sleeves though. The Oliver HG and OC-3 use the same engine as your BF. Phone # is: 717-738-2573. Hope this helps, they are very good to deal with, Dean
