5 star question
david yates
03-31-2003 20:29:27
Hello guys i got a question about my 5 star clutch pedal. This tractor i use the pedal was broke on it so i found one on a parts tractor. I went to take the one off the parts tractor and it doesnt want to come off i took the bolt out of it but it wants to stay on there is there something else i have to do to get the pedal off? Thanks!!!!! !!
Kevin Moschenrose
03-31-2003 23:10:35
 Re: 5 star question in reply to david yates, 03-31-2003 20:29:27
David, That bolt you removed is only to adjust the clutch pedal for freeplay is all. The shaft that the clutch pedal is attached to goes on into the transmission and though one side of the clutch shifting fork and it has a roll pin attached to keep the rod from being pulled out from the outside. If you email me your address I can send you a picture out of my parts book to show you what you are up against. But there is a different aproach to this too that you can try. You can take a grinder or torch and cut off that triangle piece of metal that the bolt went through and slide the pedal off the parts tractor but you still have your good tractor to deal with.
