Minneapolis Moline Tractors Discussion Forum
1948 ztu questions
BHA
05-25-2006 18:06:08
1.I have the blocks off they are cracked in the saddle where the rocker arm shaft sets.Are these fix able or junk?
2. It has m&w add power pistons. How much more commpresion are they? Will standard O.E. rings fit these ?
3.It has one 16" rim and one 15" rim on front both small bolt pattern which is correct? 4. Cam is worn does some one sell new(reground)cams?
Thanks Brad
BHA
05-26-2006 18:24:54
 Re: 1948 ztu questions in reply to BHA, 05-25-2006 18:06:08
The m&w pistons are marked STD. Which should be 3 5/8. The blocks are cracked all the way through on both sides of the bolt hole.
BMG1
05-26-2006 18:51:54
 Re: 1948 ztu questions in reply to BHA, 05-26-2006 18:24:54
If they are M&W pistons then the STD stamping means they are standard overbore or 3-3/4". They are stamped standard because they also made 3-3/4" + overbores like .040, .060, etc. This confuses many people. The only way to really tell is with a micrometer at 90 degrees to the pin bore at the bottom of the skirt. Most M&W pistons have MW cast into the pin boss on the inside of the piston.
Brian
Augie
05-26-2006 11:23:07
Hard to say on the blocks. Best to take them to your local machine shop for evaluation.
Standard bore is 3.625" - the M&W pistons are 3.75". Any good auto parts store should be able to find the right rings if you take a piston for them to measure.
Berry Cam in Lester Prairie MN has a good grind for that engine - highly recommended.
Kelvin
05-26-2006 09:56:38
You say its cracked in the saddles where the rocker arm shaft bolts. Is it cracked through to the water jacket or just between the rocker arm slots?
I think Charlie Biler sells reground camshafts for that Z engine. He's on www.minneapolis-moline website message board all the time.
I am thinking your M&W pistons will be a larger diameter and therefore will not use the standard rings. If its 3-5/8" diameter bore its standard. I think the M&W will be 3-3/4" bore.
Without consulting parts books, I would say offhand that the 16" rim is correct for your ZTU and the 15" needs to be changed out. I think it was the R that could be had either 15" or 16".
