4 star hydraulic pump
shawn g
04-01-2003 09:59:06
The hydraulic pump to shaft coupler was broken. when I went to replace this I noticed that when the pto lever was engaged the shaft pushed towards the pump (approx. 3/4") is this normal. Also is there supposed to be a bearing behind the coupler on the shaft? Any help with this situation would be appreciated. thanks
JK
04-01-2003 18:41:48
 Re: 4 star hydraulic pump in reply to shawn g, 04-01-2003 09:59:06
There should be 2 bearings on the shaft near the back. They are held in place by a tube and a copper washer that sits in a recess in the face of the hydraulic pump. If the shaft comes too far back, there must be something amiss with the adjustment of the PTO clutch assembly clearance.
John
