G1355 on auction
freddy
04-06-2003 13:12:11
Did any one else see the G1355 diesel on auction this 14th of april in Alliance, Nebraska. They say it has fluid leaking from the p/s ( I think that means 3 speed) into trans. I 've heard of some one discussing that here or on the other web chat board. Could some one shed some light on to this problem? Tractor look pretty clean in the picture, but who knows. Might be a good buy?
freddy
04-07-2003 15:38:00
 Re: G1355 on auction in reply to freddy, 04-06-2003 13:12:11
There is a good article on G1355 hydraulic problems on the other MM chat board. Good info if someone needs good cheap power for his farm. The last G1355 i seen sell didn't have as many problems but still barely made over $3000.00
Shep
04-07-2003 10:18:03
Where is the auction and the pictures. I cant go to the auction but would like to see the tractor. Thanks
freddy
04-07-2003 13:32:57
 Re: Re: G1355 on auction in reply to Shep, 04-07-2003 10:18:03
here is the link the auction
http://www.farmauction.net/forauctions/Nepper%204-14-03/Salebill.htm
m kuhns
04-06-2003 18:21:10
YOu are saying that oil is leaking out of the over/under into the main transmission? There might be a seal out at the output shaft of the over/under, or there is a seal in the input of shaft which could be leaking also. Most likely the seal on the input shaft would show signs of leakage in the clutch hsng. Either way you would have to get the over/under resealed. Email me if you need more info. or if what I think you are saying isn't right.
freddy
04-07-2003 13:35:14
 Re: Re: G1355 on auction in reply to m kuhns, 04-06-2003 18:21:10
there is not much info on it. it just says oil is leaking from ps in to trans. see sale billhttp://www.farmauction.net/forauctions/Nepper%204-14-03/Salebill.htm
