G moline for pulling
Mike
04-11-2003 20:21:45
Hi i am building a g to pull farm stock what is the best dollar for dollar mod to do to it It is a lpg tractor what can i shave safly off the heads, am new to pulling as i used to build drag cars not pulling motors for tractors Thanks for any help
Andy
04-13-2003 12:11:03
 Re: G moline for pulling in reply to Mike, 04-11-2003 20:21:45
I would make a decent drawbar and wieght brackets and try it before you start engine work. They are a great pulling tractor "as is" in stock classes. I made a pulling drawbar 20"high that pulls off the large angle iron frame under the platform. I have never killed mine in 7500-8500 lb class. It places pretty consistantly. If you want more compression don't plane your heads but find a set of 4213 or 4206 heads.
Jerry
04-14-2003 15:24:37
 Re: Re: G moline for pulling in reply to Andy, 04-13-2003 12:11:03
I would be careful about using those heads on a G unless you know the condition of the rod bearings. Those heads build a lot of compression and could take out your bottom end. The G has a real strong botton end but to much compression might not be good for it. The G has large pistons and a lot of stroke (6 inches). They build compression real fast.
Andy
04-14-2003 19:02:11
 Re: Re: Re: G moline for pulling in reply to Jerry, 04-14-2003 15:24:37
He had stated his G was LP. Those heads with LP shouldn't be a problem. The parts book lists them as higher altitude heads on a 403. Gasolene would preignite and hammer the rod and mains out unless you ran very high octane. I have 4213 heads on my GB LP and it runs beutiful.
jjmm
04-12-2003 17:30:38
what are your farm stock rules? if they dyno tractors like ours do it's 60hp for the 6000lb. class. a stock G should have a little more than that. i pull my G in 5500-6500lb. antique class, it's .090 over,little head work,big carb,racing fuel,hillbilly tuning,it dyno's close to 100hp.
