604 Diesel pump
Aron
04-13-2003 22:25:52
Hey guys, I am about ready to replace the diesel pump on my 604. I found a good pump that came off a 670 super diesel with the identical 336 motor, it's cheap too. It should line up to be an exact match.... Correct? Thanks in advance.
David
04-18-2003 09:59:37
 Re: 604 Diesel pump in reply to Aron, 04-13-2003 22:25:52
If you want to be sure, get all the numbers off both pumps and go to a Roosa Master injection shop. I'd imagine the factory fuel delivery rate on the 670 pump is a bit higher than it was on the 604, since the HP of the two tractors is not the same. Drive gear and front end are the same. Injectors may be different as well, heads are different: 604 probably used 10A4222 vs 10A23134 on 670. The 4222 head uses copper injector sealing washer, 23134 head uses transite washer and asbestos heat shield washer on the tip.
Best wishes, take care of that 604.
Aron
04-21-2003 07:36:08
 Re: Re: 604 Diesel pump in reply to David, 04-18-2003 09:59:37
You were correct, come to find out they are a little different. I had to order a pump from a 602, which cost a pretty penny, but at least it will be correct. Thanks you very much for the input.
