Hot ZA
tim
04-15-2003 07:58:27
My ZA is boiling over when pulling a 2-14 plow. Couldn't make 1/4 mile, it's pulling pretty easy, can go in 3rd, 2nd gave same result. The temp gauge doesn't work so don't know whats going on there. We put on a different (same general age) water pump and took out the thermostat - same result.
What should I look for next? Where can I buy a temp gauge?
Thanks, Tim
Alan K
04-17-2003 19:53:02
 Re: hot ZA in reply to tim, 04-15-2003 07:58:27
Is it possible you have a chunk of rust in the head that is blocking the flow of coolant to the radiator? Does it do this all the time or once in a while. We have a ZA that did this once in a while. That is what I suspect the problem was with ours. As stated the baffle plate is very important.
Alan
Curt Cooke
04-16-2003 05:42:59
Antique Gauges for the temp gauge. I think they have an ad on this site.
kelvin
04-15-2003 18:34:13
Did you reinstall the metal baffle between the water pump and the water manifold? was it in good condition with only three curved slots in it?
Other idea is plugged radiator. Or plugged radiator fins.
Bill Becker
04-15-2003 10:19:14
Take your radiator cap off while the tractor is running and see if there are air bubbles. You may have a leaking head gasket.
Joe Leising
04-15-2003 16:17:20
 Re: Re: hot ZA in reply to Bill Becker, 04-15-2003 10:19:14
Also check your valves. If you have an exhaust valve that is too tight there will be too much combustion occurring/leaking into the exhuast runner. I had this on my R. Reset the vlaves properly nad it ran fine with no overheating.
