Gear oil goes in where??
G. L. Perry
04-20-2003 22:35:08
Have a Jet STar 3 Super, been empty in gear case while working on it. No Torque on this one. Plan on using 80/90 gear oil, think it takes about 8 gallons or 32qts as said in IT manual. Now, where does it go in? There is a hex plug next to shifter, that good? There is a rubber sealed plug on side of trans case, but book says for clutch adjust or such. Any place else? I don't have the owners/operators manual to tell me this stuff and don't see it in the IT book. Lookin' like shifter plug to me, real slowly I presume?
Doug
04-21-2003 19:31:16
 Re: Gear oil goes in where?? in reply to G. L. Perry , 04-20-2003 22:35:08
Yes, take the hex plug out of the top next to the shifter. That is where you put the 80-90 in. On the right side of the transmission there are 2 small plugs. Remove the lower one (I believe it is by the brake pedals) and fill till oil comes out there.
