Minn-mo serial numbers
Terry Zwart
04-22-2003 06:58:56
I'm looking for information for a friend on a tractor that he received from an estate. It's a Minneapolis Moline EE with a serial number of 414367. Any information would be great. We don't even know the year. Please e-mail me.
Thanks,
Terry
BMG
04-22-2003 17:09:01
 Re: Minn-mo serial numbers in reply to Terry Zwart, 04-22-2003 06:58:56
Terry,
You're friend most likely has found a 1946 R model tractor. The EE engine was only found in the R model. The RE engine came in the ZT model tractor. The serial you listed is from a 1946 EE engine. Check the right side of the trans housing above the belt pulley and in front of and below the hand clutch lever. I think Kevin meant to say R in stead of Z in his post below but just wanted to clarify for you.
Brian
Kevin Moschenrose
04-23-2003 08:10:51
 Re: Re: Minn-mo serial numbers in reply to BMG, 04-22-2003 17:09:01
Thanks Brian, I knew someone would cover my back on that. LOL I couldn't back up once I posted.
Tyler
04-22-2003 11:11:50
I believe the "EE" engine was used In the R Model, not the Z.
Kevin Moschenrose
04-22-2003 11:01:20
That is just a number off the engine is all. There is another one or should be one back on the trasmission housing by the brake pedal. It is a the motor number tells me that it is a 1946 and that it would be in a model "Z" tractor. That is if it has not been switched around.
Terry
04-22-2003 11:03:17
 Re: Re: Minn-mo serial numbers in reply to Kevin Moschenrose, 04-22-2003 11:01:20
Thanks for the info. I'll have him look there.
