MM please help?
Hawkeye
04-22-2003 16:00:31
I have found a MM tractor. Im not sure what model it is. It is a small tractor. It has bf avery trans in it. the only numbers I can find is, 205865 on the trans and 1178490 on a plate on the head. any help would be appericated.
hawkeye
04-26-2003 04:24:15
 Re: MM please help? in reply to Hawkeye, 04-22-2003 16:00:31
Kelvin all thats is right , thanks
Kelvin
04-24-2003 19:21:25
B.F. Avery cast right in the side of the transmission? Shifter is a flat bar comming out the top near the right side of the transmission?
Frame made of about 3" formed channel? engine drives the transmission with a driveshaft that has a sheetmetal cover? Steering wheel supported by a pipe that curves up off the left frame rail, the ignition switch in a casting at the bottom?
If all this sounds right, you probably have a MM model V.
Aron
04-22-2003 22:25:41
I am not 100%, but it sounds like you may be dealing with an MM "BF".
