M602 rear seal
twopop
04-24-2003 18:07:03
would appreciate some info about changing the, rear main felt seal,on the subject tractor.Can it be done without removing the engine? and how is it done. TIA
twopop
SWMolines
04-26-2003 19:44:33
 Re: m602 rear seal in reply to twopop, 04-24-2003 18:07:03
It can be done. I will not say it is easy. The pan can be droppped, the rear main cap removed and the seal retainer pulled out. Using a seal extractor, the old seal can usually be pulled out. Sometimes the old seal is really stuck in the groove and will not pull out. I have had to use wood screws etc.....to get a good enough grip on the old seal. Once you have it pulled out, the fun is just starting. Feeding the new seal back in can be even more fun. Most seal kits come with a cable used to pull the seal around the top side of the crankshaft. Lube the seal up good and pull it into the groove.
This is the short course on installing a real main seal. If you have done this sort of thing before I am sure I have given you more information than you needed.
Good Luck!
