Camshafts 10A30435 and 10A19776
freddy
04-26-2003 12:15:03
Does any one known which engines these camshafts were originally installed in. Looking to put one in my tractor puller. They have higher lift. .379 instead of my .340
LW
04-26-2003 19:55:29
 Re: Camshafts 10A30435 and 10A19776 in reply to freddy, 04-26-2003 12:15:03
I would have to go back and and find where I checked all those the late 336 had a higher lift grind and also 108degree lobe seperation verses the older 110 it will run better, if you want a pullin cam though I can get you about14 to 16 hp on a high compression 403 at stock rpm's, more so on bigger engines.
