MM G PROBLEMS
David
04-28-2003 14:22:13
I have had trouble with the tractor not running on the #1 and # 4 cylinders. I checked the compression in all cylinders and 180 psi in each cylinder, I checked the spark had a good blue spark on the plug. I rebulit the carb. and now it runs better but it still isn't right and now the trouble is on # 2 and # 3. With the engine running and I pull the wire off the distributor off of # 2 or # 3 and you almost can,t tell that you pulled it off, If you pull it off # 1 or # 4 it really changes. I am at a dead end road and need help.
THANKS FOR ANY HELP DAVID North Carolina
LW
04-29-2003 19:15:10
 Re: MM G PROBLEMS in reply to David, 04-28-2003 14:22:13
Did you recently have the heads off? You know you need to use the manifold ( one that is flat) to line them up before you torque them down right, did you check the distributor for wear, the bushing or thrust washer could be badly worn, the bushing being worn will reak havoc, very speratic.LW
Bob M
04-29-2003 04:23:16
David - Might be a leaking intake manifold. With the motor idling liberally spray WD-40 around the gasket area where each manifold runner meets the block. If it starts hitting on the cylinder fed from that runner while you are spraying, you've got a manifold leak at that point.
Also have you tried installing a fresh set of spark plugs??
Jim Park
04-28-2003 19:09:13
Tom, Try A New Distributer Cap& Wires. It Might Do The Trick.
Kelvin
04-28-2003 17:03:12
David,
check your firing order: 1,3,4,2. Also, you might try swapping the primary wires on the coil. It makes a weaker spark one way than the other and I can't tell you which is correct.
Also, you might check your valve clearance. I'm thinking it should be .008 on the intake and .010 on the exhaust.
P.S. what part of NC are you in? I live in Richfield-about midway between Charlotte and Asheboro.
David
04-28-2003 20:01:44
 Re: Re: MM G PROBLEMS in reply to Kelvin, 04-28-2003 17:03:12
I live in a small town called East Bend it is about 20 miles west of Winston Salem on Hwy. 421 This tractor has a new distributor cap and rotor this thing has a good spark at the spark plug, I checked the valve clearance that all checked good the firing order is correct. I'm very thinkfull for your help. DAVID
Pete Brandel
04-29-2003 16:10:34
 Re: Re: Re: MM G PROBLEMS in reply to David, 04-28-2003 20:01:44
Dave,I had the same problem with a MM U.I replaced the complete ignition,carb,adjusted valves,checked compression,but still had the weak miss.It was real slow to rev up when you hit the throttle and you had to choke it to start it almost all the time.I tried the WD 40 trick by spraying it on the manifold to see if the gasket was leaking.I finally replaced the intake-exhaust manifold and it ran perfect.I took the intake off of the exhaust manifold and found carbon in the intake port inside the exhaust manifold.It had an internal crack on the intake port.It did not have an external crack anywhere.The manifold on the outside looked perfect.
David
04-29-2003 16:20:40
 Re: Re: Re: Re: MM G PROBLEMS in reply to Pete Brandel, 04-29-2003 16:10:34
I would like to thank all you guys for the help,
I will try all of the tricks on Wednesday, and if anyone has any more I'm open for all suggestions.
THANKS DAVID
Kelvin
04-29-2003 19:11:26
 Re: Re: Re: Re: Re: MM G PROBLEMS in reply to David, 04-29-2003 16:20:40
Thanks for sharing that manifold idea with us Pete. I've heard it was common on some Allis models, but never have heard it happening on MM's.
Jerry
04-30-2003 13:35:57
 Re: Re: Re: Re: Re: Re: MM G PROBLEMS in reply to Kelvin, 04-29-2003 19:11:26
Your condenser might be shot.
