Is it ok to use unleaded gas in a 1960 JetStar MM Tractor?
Ken Bursaw
05-08-2003 08:53:13
david stephenson
05-17-2003 16:25:37
 Re: Is it ok to use unleaded gas in a 1960 JetStar MM Tractor? in reply to Ken Bursaw, 05-08-2003 08:53:13
we use unleaded gas in all the tractors at the farm and they were made back in the 40,50,60, and work fine on it, john deere farmall and 445moline
havey
05-10-2003 06:35:48
i have run many older tractors on unlead no problems the previous post is also correct in my opinion i would however if rebuild was needed upgrade to harden valve seats and quality valves stelite etc
Dale
05-09-2003 06:50:33
Go ahead and use it, it won't make virtually any difference on a tractor. The lead additive was supposed to help valve life. Used valves have metal worn away through normal use and lead additive will not put anything back. Probably small older tractors aren't used as hard as when the original owners bought them so the wear from here on out will be limited. If a tractor needs a valve job, that needs to be done regardless of the gas used. Dale
