MM U cylinders
kevin osborn
05-11-2003 08:50:55
How do you get the cylinders out of the block of an U? I have the heads off, but they still seem to be pretty solid. Thanks
LW
05-11-2003 14:03:17
 Re: MM U cylinders in reply to kevin osborn, 05-11-2003 08:50:55
Thier cast in the block, the blocks should come off with a little persuasion they may have the dowel pins in it if its factory , so you will have to pry them up.
Jerry
05-11-2003 15:50:32
 Re: Re: MM U cylinders in reply to LW, 05-11-2003 14:03:17
Hi: I grind a cold chisal to a very sharp knife edge and keep going around the block with a 8 lb hand sledge hammer. Use care as they can be broken.
